How hard is it to do the brakes on a 2014 Cruze? I've never done them myself but sort of want to try, when the time comes. Are they the discs or rotors? Also are there any videos and what kind of tools will I need? How long can I expect it to take?
Welcome to the forum. How many miles do you have on your car and what kind of 2014 Cruze, Front/Rear. Fronts I would look at @35K. You may need to adjust the rear drums. Front is disc and the rear depending on model is drum. Regardless the fronts are easy. There are several how to posts about how to do the front. If you have anything other than a LTZ, chances are you have drum on the back and probably need to be adjusted. Check the first few how tos in here:http://www.cruzetalk.com/forum/153-gen1-brakes-suspension-tutorials/.
Give it another 3-4 years.I'm at 17,452. Bought it with 17,000. I have the ltz model. Thanks I'll check out those guides!
uh looked like general discussion on my mobile, can some one move it?uh, this is the diesel section
That will depend on the type of driving you do (hwy vs city). Hwy they may last that long city you have lots of stop and go which will wear them quicker but the ceramic pads put on the Cruze will last a good long time. I only had to change mine at 38K bc my front calipers were seized and it was like I was driving with my brakes on always. If not I probably could have left them go to @50K esp since I do lots of stop and go. If I were you, I would check @40K miles not KMThey'll really last that long? Wow that's impressive.
I didn't change my fronts until 71,000 miles and still had a little meat on the pads. The rears are drums and I still am running the originals.They'll really last that long? Wow that's impressive.
