IT is. Same bulb for the Brake/Taillight and the Taillight only.So . Is IT the Bulb in the O Book ?
If you are referring to the disparity in output between running light and when the brakes are applied, our LED bulb replacements are all designed specifically with that functionality in mind.It's not a question of working as much as cost. Brightness = $$. I'd hate to buy a more expensive LED for the "bright/dim" function when the car only uses "dim" for that socket. But I'd have to see if there is a socket compatible version that's only the dim. There may not be.
Understood.If you are referring to the disparity in output between running light and when the brakes are applied, our LED bulb replacements are all designed specifically with that functionality in mind.
You could go with an HP48 for the inner section, and maybe something brighter for the outer spot, like an HP11 or XP80Understood.
The Cruze has 4 taillight sockets used for running lights. Only two of those sockets are used for brake lights. But the same bulbs is specified for all 4 sockets. It seems like I should be able to buy a cheaper "taillight only" bulb to use for those two sockets. But I'm not sure such a thing exists.
That's certainly an idea. Although I think because of reflector design, those lights already seem dimmer.You could go with an HP48 for the inner section, and maybe something brighter for the outer spot, like an HP11 or XP80
The HP48 utilizes factory reflector housings nicely due to it's diffusing lens and reflective topThat's certainly an idea. Although I think because of reflector design, those lights already seem dimmer.
We have over 4x the normal traffic on our site today. We beefed up our server and made some changes to the site, but we are incredibly busyYou guys must be getting hammered today. It took over a full minute for the order to go though.
Also, you're missing an opportunity - you don't have any options for the Cruze interior. Nothing for map (W5W), dome (W5W), or vanity. And nothing showing the add-on footwell kit.
That's cool, but that's not what I'm addressing - it's a catalog issue. Other than the trunk light, there's no interior options in your catalog listed under the Cruze. I know that's not true (my car is proof of that), but that's what your web page shows.Ideally we will be bringing a Cruze into the studio for full interior comparison shots and installation videos, but it takes time. We bring a new vehicle in every week
That's because we haven't had a Cruze in the studio. We don't like to list interior locations unless we've had one in the studio to confirm fitment.That's cool, but that's not what I'm addressing - it's a catalog issue. Other than the trunk light, there's no interior options in your catalog listed under the Cruze. I know that's not true (my car is proof of that), but that's what your web page shows.
