To go the "Budget Way" I went with the Spec D Fog Lights (https://www.amazon.com/gp/product/B01DMSUYRK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1) and purchased the OEM Fog Light Switch (13295227) off Ebay. The fogs came with a Spec-D non-oem harness so I cut off the relay and switch. I found out that the correct pin to use for the fuse panel harness is p/n13575773. You can crimp or solder that pin/wire to the positive wire on the harness and install it in the under hood fuse panel harness then attach the ground and you have OEM style setup for $70 for everything. I also got these to match my headlights. (https://www.amazon.com/gp/product/B01MY2A8W3/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1).
Sent from my SM-G930V using Tapatalk
