Hello everyone.
I will be looking into pulling the head on my LUJ for a low compression issue on one of the cylinders. I figured since I had it off, I would do some porting/cleanup and install stronger springs.
I was curious if anyone knew the specs for the cams in the LUJ and is it the same as the LUV? Is it also the same as the N/A LUU from the Volt(84hp) or are they the same as the cams from the N/A LDD and L2N(99hp)?
Any info would be great.
Thanks
Thanks
