1 - 9 of 9 Posts
I need help identifying this part circled in red .. I’ve been searching online for hours and find the part name .. I did figure out the name for the part it’s attached to and even have the part #
Engine Oil Cooler and Oil Filter Assembly - GM (55566784)
Musical instrument Idiophone Bicycle part Personal protective equipment Audio equipment
It’s got a metal aluminum sheath wrapped around it and it’s cover a little black plastic connector hose thingy
Hi I am looking for the wiring that connects to that sensor because it is broken and I have the new sensor but cannot connect the connector from the wire harness thank you
Welcome Aboard!(y)
Thank you so much ! I am not knew here been a member almost a year now I own a 2011 Ltz 1.4 turbo and at 178000 she still has alot of gremlins to work out
Sorry, I must have looked at the OP's join date. Glad you found what you needed.
1 - 9 of 9 Posts
