1 - 20 of 46 Posts
I recently purchased a tune from Trifecta via BNR during the recent group buy. I installed the tune and while there is more power throughout the power band, I also experienced pretty bad surging under boost. I data logged and received a response that my tune was good to go as is. I did not purchase a Forge bypass valve. Could the surging be the factory valve struggling to control the increased boost from the tune?
Did you verify your spark plugs are all at 0.028"?
That is the exact same experience I had with the tune. Power delivery was not smooth as all. It was like I was letting off the gas then back on then back off etc. The tune they did for my auto 2012 was smooth right from the start.
But I haven't heard anything back about the data logs I sent.
Do you have a boost gauge? I installed Forge BPV, gauge and tune at same time. I can hold 23psi no problem in power mode
There are no physical changes needed for the Trifecta tune other to properly gap the plugs. Vince @Trifecta actually recommended 0.027" for tuned engines but said that 0.028" would work.
When I first got my tune back in summer of 2011 - 2011 ECO 6M - my car would run rough under load. Was told the original tune was developed on an Automatic Cruze and my car was boosting too much at too low an RPM. I contacted Vince-it was a known issue and Vince sent a revised tune and has been good since then.
Put your plug gaps back down to recommended, and try it again. Too large a gap will make the car cut out.
Plugs are now gapped at 0.027" but now software won't connect to car.
Uninstall ez flash then go to http://www.wot-tuning.com/files/file/1-ez-flash/
Download ez flash from here and the corresponding drivers. Then re flash the car. I was having problems with the links provided by bnr so I used these. The drivers are different on this page and its a newer version of ez flash.
Sent from my beast GS4
Discussion Starter · #19 ·
You may be right with the re-downloading of the files. I am on a different computer than the first time I tuned, and I vaguely remember having the same problem. It's all coming back to me now. Thanks for the reminder. Here goes nothing.
1 - 20 of 46 Posts
