1 - 4 of 4 Posts
Good Evening,
For the past couple of days I noticed while the car is in motion I get heat but if I ever stop (let's say while in traffic) I'll notice it'll get cold which is odd as that shouldn't happen.
Is there something I can check to isolate what the issue might be?
Might be an issue down the line when it gets colder haha
Thanks in advance.
There is an air pocket In the heater core causing this.
Check your coolant level in the reservoir, I would be willing to say it is either low or empty. If so you need to be looking for a leak. Common areas for leaks are the water pump, thermostat, water outlet, and hoses.
Discussion Starter #3
I'll definitely look into that soon.
To recap we are talking the coolant reservoir for antifreeze correct? If so I suppose it's best for me to check after the car sits idle for awhile to properly gauge it. (Atlwast that's what I was told before about that)
I'd like to add when I had the car idle in parking lot when I had the car go from 1 to 2 on the rpm I wouldnt get warm/hot air but when I got to close to 3 and let it stay there for awhile I'd get hot air....
Of course if I let it go and go back idle it would eventually go back cold.
I'll assume you have verified the coolant level is correct.
Is this car new(ish) to you and what is the ambient temperature where it is being operated?
1 - 4 of 4 Posts
