1 - 2 of 2 Posts
Hi,
I am having a problem with my 2014 Chevrolet Cruze 1.8 LPG.
Sometimes the car starts stuttering a little bit, and different lights on the dash turn on at the same time: Stabilitrak, ABS, handbrake, parking sensors (??).
The screen also says "CODE 89" plus sometimes "CODE 139" if i recall correctly.
After a while all the lights turn off and only the stabilitrak error stays on.
At this point if i turn off the car it doesn't start anymore.
I tried another key but it didn't work.
Lately i found out if i disconnect the battery for some hours it will startup again.
My mechanics diagnostic tool returned different errors that don't seem related to the problem.
Is it possible that the ECU/ECM is broken?
Unless water is getting into them, the computers are generally robust. I think you're much more likely to have some flaky wiring confusing them.
1 - 2 of 2 Posts
