1 - 3 of 3 Posts
So recently I've been having some trouble with my 2012 Chevy Cruze 1.8 l I turn my car on and the battery clicks and then the car starts and then as soon as the car starts the flashers flash windshield wipers turn on trunk opens trunk won't close even though the car is on I have to slam it really hard to get it to close is this a battery alternator or ground issue
Vectra C SW Elegance II, Z18XER, '07; Astra F SW Sport, X16XEL, '95; Astra F CC Euro 96, X16XEL, '96
Welcome to CruzeTalk!
You should check charging voltage and battery status. By professionals would be best.
I'm not saying this will fix anything, but it's worth a try and it's free and easy.
After you've verified your battery is properly charged as suggested above, try unhooking the battery negative and let it sit for 5-10 minutes, then hook it back up. I've had some real odd crazy behavior with my sons Cruze a couple of times, all kinds of wonky stuff after a low or dead battery. So charge it fully, then unhook it for a bit to clear everything, then hook it back up and see if anything changed.
1 - 3 of 3 Posts
