Is there anyway that your code was a P11D7 instead of P11DC? I ask you because I have got this code a couple of times in the last 35K miles. I bought a code reader soon after a couple CEL's right after I bought the CTD to avoid the dealer visits.
P11D7 is a NOX sensor calibration signal problem. I cant help with a P11DC. Sorry.Is there anyway that your code was a P11D7 instead of P11DC? I ask you because I have got this code a couple of times in the last 35K miles. I bought a code reader soon after a couple CEL's right after I bought the CTD to avoid the dealer visits.
The paperwork from the dealer said. "Check engine light is on - Cau diagn dtc P11DC, ,test per PIP5135 Found leaking air cleaner outlet duct." Replace duct assembly.P11D7 is a NOX sensor calibration signal problem. I cant help with a P11DC. Sorry.
Nothing abnormal, however, I thought the mileage was a little lower than normal.Great. Thanks for the follow up. Did you notice any fuel type smells in the car especially at idle ?
Sorry to hear. I'm at 32k 1-O2 sensor, 1-NOX and the air duct. Good luck.Gonna bump this thread ... Got CEL yesterday morning, same P11DC, phone doesn't have details for it. No real fuel smell, but have have noticed a solid 5mpg loss based on what would be "normal" for me. (Usually 49-50mpg per 25miles straight highway, now lucky to hit 45mpg..)
Car goes in tomorrow. Again. 6th time in only 18k miles !
Tomko this motor does not have a knock sensor. checked all 8 pages of wiring diagrams for eng management at work yesterday an it is not there. the normal noise from this eng would drive a knock sensor crazy.Given that Diesel engines do not have an ignition system, I had no idea that they had a knock sensor.
Ok so dealer just called and told me a/the knock sensor failed. Not sure if/how that's related to P11DC ?
Thanks oilburner.Tomko this motor does not have a knock sensor. checked all 8 pages of wiring diagrams for eng management at work yesterday an it is not there. the normal noise from this eng would drive a knock sensor crazy.
Any chance you could post this information for P11D7 as well? I've been trying to locate the cause of that code on my vehicle, but all I can get is that it generally has something to do with a NOX sensor, but no data as specific as this.![]()
2014 Chevrolet Cruze 2.0L Eng Diesel
Circuit/System Description
The reductant system uses two nitrogen oxide (NOx) sensors to monitor the amount of NOx in the engine's exhaust gas. The first sensor is located at the outlet of the turbocharger and monitors the engine out NOx level. The second NOx sensor is located after the selective catalytic reduction (SCR) and monitors NOx levels downstream of the SCR.
Each NOx sensor contains a sensing cell, a pumping cell and a heater. A sample of exhaust gas passes through a diffusion gap between the sensing cell and the pumping cell. The NOx sensor maintains a constant reference voltage across the sensing cell. An electronic circuit within sensor controls the pump current through the pumping cell in order to maintain a constant voltage in the sensing cell. The amount of current required to maintain the reference voltage in the sensing cell is proportional to the concentration of NOx in the exhaust.
The ECM varies the amount of diesel exhaust fluid (DEF) or reductant added by varying the reductant injector duty cycle in response to changes in engine exhaust out NOx levels.
The smart NOx sensors consist of two components, the NOx module and the NOx sensor element that are serviced as a unit. A circuit or performance condition with a NOx sensor is detected by the NOx sensor module. The smart NOx sensor module communicates the condition to the ECM over the serial data line. The ECM sets a DTC when a serial data message is received from the NOx sensor module.
P11DC
- DTCs P064C, P163C, P220A, P220B, P22A3, P229E, U029D and U029E are not set.
- The EGT sensor 3 is between 100-600°C (212-1112° F).
- The engine speed is greater than 600 RPM for 5 minutes.
- The battery voltage is greater than 11 V.
- NOx sensor 1 and NOx sensor 2 status shows activity.
- The fault exists for more than 3 events during a key cycle.
- The DTC runs continuously when the above conditions are met.
Are you sure they said KNOCK SENSOR and not NOx sensor? Sounds the same. Could be a misunderstanding. Just wondering.Ok so dealer just called and told me a/the knock sensor failed. Not sure if/how that's related to P11DC ?
Would make sense though with loss in mileage as I'm sure motor is in limp mode.. Will try to log it to verify for my own sake.
Told me to pick the car up while they wait for the part, claims its ok to drive for now based on GM tech. I'm not risking fouling out the exhaust system again, so probably DD the racecar for now ..
Circuit | Short to Ground | Open/High Resistance | Short to Voltage | Signal Performance |
NOx Sensor Ignition Voltage | U029D, U029E, P220A, P220B | U029D, U029E | U029D, U029E, P220A, P220B | - |
High Speed GMLAN Serial Data (+) | U0074, P205D | U010E, P205D | U0074, P205D | - |
High Speed GMLAN Serial Data (-) | U029D, U029E, U010E, P205D | U010E, P205D | U010E, P205D | - |
NOx Sensor Ground | - | U029D, U029E | - | - |
I'm going to, after reading the thread, redefine (if needed) that the dealer probably called you to say the NOx sensor failed….that was likely interpeted as the 'Knock Sensor' failed……and reported as such.Ok so dealer just called and told me a/the knock sensor failed. Not sure if/how that's related to P11DC ?
Funny thing is when he called I said KNOCK or NOx ? And he said no, knock is in knock on the table ... So I said well wtf do I know, I'm new to the whole clean diesel world anyway.Are you sure they said KNOCK SENSOR and not NOx sensor? Sounds the same. Could be a misunderstanding. Just wondering.
