1 - 2 of 2 Posts
2017s don't use 9012s. The catalogs are wrong. Gen2s use 9005SL+ bulbs from the factory. I've never seen a single Gen2 with 9012s.
That said if you wanna upgrade to an HIR bulb, you'll want a 9011(HIR1) bulb. Ideally the GM or Toyota OEM bulb, with the spherical capsule. If you can find those or don't wanna spend the coin, Sylvania 9011 should be high quality German made OSRAM bulbs in the package, avoid Wagners and any bulb made in Asia.
What's the diff between the 9011 & 9012 ?
They are two different bulbs....
They have different connector features, they have different base diameters, they have different locking tab configurations.
9011 is "basically" a very hot rod 9005
9012 is "basically" a very hot rod 9006
Besides one small modification to the top locking tab that needs to be made, a 9011 is a direct replacement for a 9005. It has the same mechanical dimensions, the same electrical and thermal properties, and the same light aim properties. It just puts out a bunch more light. No other bulb can have that said about it...Not LED, not HID, not candle, or arc reactor.
1 - 2 of 2 Posts
