For the 1.4's once they start leaking oil it is generally a PCV situation... A two integral piece system. One piece being the intake manifold, containing a check valve to prevent turbo boost from pressurizing said engine cavity. And the valve cover, containing the pressure regulating diaphragm.
Looks like they replaced the intake manifold, but is there anything noted on the valve cover?
Axle seals can be finicky, but not as finicky as hitting it with some brake cleaner, "note to the mechanic"
