I don't fully comprehend the logic behind this either, have type A codes that once set, stay set, even after the problem was solved, leaving out the dip stick or evaporative emissions codes are this way. Type B codes would reset themselves once the problem was cured.
With On Board Diagnostics, or OBD I that died in model year 1995, didn't even need a scanner, but all manufactures used that own type of diagnostic connector. But didn't even need a scanner, a paper clip wire would do, but you needed a shop manual to identify the code and which pins to jumper to read it. Vehicles like my 88 Supra or 92 DeVille would digitally display the codes, but you had to know which buttons or pedals to press to display them. Others, had to count pulses by looking at the check engine lamp. And the codes could even be reset without a scanner.
But all this changed with OBD II starting in the 1996 models and this BS has been going on for twenty years now. The EPA did standardized the diagnostic connector and some of the emission codes, But a second or even a half a dozen more computers were added that also can generate codes, and for each manufacture, they are all different.
The fact of the matter is, these codes are stored in the vehicle in flashram, but they are not displayed, need a way overpriced scanner to do this. Circuitry wise, this would add about two bucks to the cost of the vehicle.
To further complicate matters, and kick me off this board if you want to, but telling it the way it is, GM has been extra nasty on this matter by translating a good number of codes that only can be read with a GM Tech II scanner. If read with a much cheaper generic scanner, will get a code that is not even in the book!
But knowing the exact code is worthless without a shop manual, if laying out 200 bucks for a shop manual isn't bad enough, the new price is 375 bucks! They want you to go to your dealer, found one decent one that would read the codes, make sure you have a pencil and a paper and look over the shoulder and write them down for 30 bucks.
Or as suggested, scribe to OnStar, but still need the shop manual to decipher what this code stands for, something like over 400 different codes. And you really don't know if your oil cap is loose or if your engine is going to become toast.
If everybody knew what was going on, we would leave them in the showrooms until they let us know what's wrong with our vehicles.
Reminds me of that space odyssey movie with HAL, that crazy computer, but HAL stands for Heart Attack Lamp in this case.
