Check engine light p0299 turbocharger underboost
10113 7
2013 Chevy Cruze 46000 mile check engine light keeps going on and off every couple days went to AutoZone and had them pull a code for me. was reaching out for some help is this covered under 100000 powertrain warranty? does this mean I need a new turbo charger? Is it bad to drive around like this if feels fine to me I don't notice anything different. Thanks guys
1 - 8 of 8 Posts
Usually wastegate pivot pin wear and the turbo will no longer build enough boost to satisfy the car. Wait for the CEL to come back and take it in; it is covered by powertrain.
wouldn't the light stay on until the code is cleared...? Or I like when you have a misfire it flickers when computer senses misfire..
No. Certain conditions are calling for more boost than it can deliver. Just like it takes multiple instances to set a check engine light, after multiple cycles of NOT seeing a condition reoccur, the car will turn the CEL back off and delete the code.
Would using some type of high temp grease on the pin such as break caliper grease prevent this?
Might prolong its life a bit. It seems like the Cruzes ECM is very busy battling knock and trying to advance timing most of the time, and it flutters that wastegate a lot under acceleration.
it turned off on me again before I could bring it in. I have the paper AutoZone gave me but I have a feeling they're going to say they can't do anything unless the light is on so I guess I'll wait for it to come on again
1 - 8 of 8 Posts
