That was told on here I may have a check valve problem. In the past 6 months I had a turbo replace and I had leaks in the head gasket and oil pan gasket. Also I notice my car has a rough idle sometimes at stop lights.
Yesterday I tried to check check well I remove the metal clip clamp but I could not get the hose off to look inside for the nipple. Is there a trick to getting it off ? me and my dad were scared we were going to break it if we pulled any harder? My 100k 5 year warranty will be running out I just had all those things fixed under warranty and I'm worried I'm further damaging them again by driving with a bad check valve. Any help would be appreciated thank you
I'm not sure about the oil cuz I don't do my own oil changes but they've never said anything. But I wouldn't doubt it. It's a 2013 with 54000 miles. I just don't want to pay the $125 diagnostic to check it and not have a problem then I wasted the money which I don't have. But From what I've read on here it happens to everyone's in between 50 and 60 thousand miles. If that's the case they should have had a recall
There's a TSB out for it. Covered under powertrain warranty.
The tube is sealed to the intake manifold with a rubber gasket inside. Pull straight up, firmly, on the hard plastic part. The corrugated hose part can be quite brittle, so don't flex it too much.
