Hi there,
I have a 2015 Chev Cruze 1.4L Turbo.
Engine ran perfectly fine and then shut off, came back and it wouldn't start up. Pushed into warm shop (in Canada, about -10C) to try to diagnose, ended up trying it again after a few hours and boom it went, ran fine for about a 30 min drive home. Then, tried again after a few hours (in cold) and it won't fire.
The engine will crank but will not fire and stay running. It sometimes tries to fire (you can feel it fire but immediately shuts off). Most times it doesn't even try to fire, though, just cranks.
I checked fuel pressure on the rail and it shows 55-60psi. Fuel is there.
Tested coil and all 4 spark normally with test plug, seems good.
Replaced spark plugs and battery with no change, other than turns over much better.
New spark plugs were dry after trying to turn over. Put a few drops of fuel down each cylinder and it fired for 10 seconds then shut off again.
It seems like it's not getting fuel... what could the issue be?
Engine seems to have compression, but I don't have a compression tool handy to check exact values.
Fuses all good. I also swapped out the ignition/fuel relays and no difference. Also, no engine codes coming up on OBDII reader.
Thanks for the help in advance.
