I have Chevrolet Cruze 2012 Korean model i went to the service and they upgrade the BCM programming after that i found the remote lock feedback the first press locks the doors silently and if you press again it will toot the horn to confirm, is that normal and how can i change it as first the first press toot the horn and close the doors just with one press?
You should be able to adjust it by going into the configuration menu on the radio and to the lock options.
i did that and select horn & Light but it make horn & Light after the second press the first press only makes light only?
I actually changed my Cruze to this configuration. In the radio's configuration menu is a section for lock alerts.
i did that in the option i make it light and horn but also when you close it first press locks the doors silently and if you press again it will toot the horn to confirm
