Chevy Cruze Fiberglass Subwoofer Boxes/Enclosures
45623 Views 53 Replies 29 Participants Last post by  billseast
3
Fiberglass subwoofer enclosures are finally here!
After a long delay, we are ready to start taking orders on fiberglass enclosures. These are built solid as a rock out of thick fiberglass by hand here in the USA. Nope, this isn't some Chinese crap. This is quality American craftsmanship, with great attention to detail, precision routing, and pride in workmanship.
Specifications:
Internal Volume: ~0.7 cubic feet
Maximum mounting depth: 6-3/4"
Subwoofer diameter: 8"-12"
NOTE: THIS DOES NOT FIT IN THE CRUZE DIESEL.
Each enclosure can be routed to the specifications of your subwoofer's cutout diameter.
Enclosures come in two finishes; either carpeted to match the trunk of your Cruze as shown in this 10" enclosure:
Or painted as shown in this 12" enclosure:
Pricing:
Carpeted: $225 + $30 shipping
Painted: $375 + $30 shipping
How do I place an order?
Send me a private message with the following information:
1. Subwoofer you intend to use
2. Carpeted or painted
3. E-mail address and phone number
4. Mailing address
Disclaimer:
Be advised, not all subwoofers sound good in 0.7 cubic feet of internal space regardless of what the manufacturers may claim. I'd be more than happy to model any subwoofer you'd like in this airspace to give you an idea of whether or not it will sound good free of charge. I can also recommend specific subwoofers if you don't already have one in mind. If you want to buy an enclosure with a sub already loaded, we can get brands like Rockford Fosgate, Kicker, Pioneer and others at wholesale prices. Just let me know and I can give you some options.
Refer to the first post in the following thread for any available deals on subwoofers:
http://www.cruzetalk.com/forum/36-a...0-xtremerevolution-co-mobile-audio-parts.html
Please note that pricing can change at any time.
21 - 40 of 54 Posts
JL10W3v3 would rock this enclosure but it's a pricey sub, $220-260ish price range.
They only need .625 cubic feet are 150-500 watts, sounds good at low and high wattage. Only single voice coil option of 2 & 4. Oh and under 6" mounting depth. I know JL's are not everyone's 1st choice but I'm sure these will make tons of noise in that little box. My two cents.
It works well in this box, I will give it that, but I want to be clear on why it's not my first choice.
At $200 (amazon), it is very low on my list of recommended subs due to price. You pay a lot and get very little. The TC Sounds Epic 10 is not only a far more powerful sub, but is also a far better sounding sub. Compared to the JL10W3, it has:
- a much stronger motor (and visibly larger)
- a lower moving mass
- a higher peak handling capacity (re: higher mechanical excursion at 2" peak to peak)
- a significantly higher linear excursion (compare 14mm to 18.1mm)
- a cast aluminum frame instead a cheap stamped steel frame
- a shorting ring (re: better sound quality via lower distortion)
- higher efficiency at the same impedance (due to the much stronger motor and lower moving mass)
All this, and it costs $12 less to boot. The JL 10W3 isn't even in the same league as the TC Epic 10.
That's what you trade when you go with a big brand name like JL Audio, and that's why nobody here has ever seen me recommend them. They are not bad subs so to speak, but they are a horrible value. In the years I've spent in car audio, I've never seen an exception to that statement. I'd love to say there's something special about them, but there isn't. They plaster marketing jargon all over the site. "Patent this, patent that, we are the greatest." They are simply the most heavily marketed. There is always something that sounds better, hits harder, is built better, and is cheaper for the same price.
Now that's a comparison at the $200 price point. Move into the $220-$260 price point and you have the following subs to contend with:
The HiVi SP10 (check out that motor. 2x the weight of the JL)
The Madisound Speaker Store
The Peerless XXLS (amazingly low moving mass and a pure SQ sub)
The Seas L26RO4Y (Very strong motor, low moving mass, great excursion, and VERY low Qts. 2x the weight of the JL)
When I look at these options, the only reason I'd buy the JL 10W3 is if I needed the brand name label on the cone to show off to my friends because they've never heard of HiVi or Seas or Peerless or TC Sounds before. Comparing these 3 subs and the TC sub to the JL 10W3 is like comparing a Cruze to an Aveo with a $30k price tag.
We have on box that is built to hold a 10". Its the first of the Cruze fiberglass sub boxes. The box is used in the picture that you see in the first post of this thread. We will sale this on off quick for $200 shipped.
Great Job! Will save up for one! M
ike
hi
tell me if i'm wrong, but is it possible that with a well adapt to the enclosure 12" sub you will end up with a more sensitive sub that will work more easily at lower frequency ?
on one side you have a cone with more surface but who is heavier and not to forget the inner volume of the enclosure 0.7....... or 10" is the sweet spot
i'm very interested by the enclosure, just not sure what to put in it
And Xtrem you have a PM........for a while now ;-))
hi
I may have missed your PM. I get several each day.
I would recommend a 10" sub. A 12" us a bit too large for this enclosure and volume. It will be difficult to find a 12" sub that actually sounds good in that small of an airspace.
Sent from mobile.
No problem i can easily imagine the volume of all you have to answer.......
What would be the ideal 10" (or 8" ?) to match your enclosure having SQ in mind ?
Maybe having a small list of sub in 3 price range that would be best suite for you enclosure would help.
I'm very curions to have the shipping price for the enclosure alone and for enclosure + a sub in place
i just find a used sub, Focal P25DB and a JL mono amp
my only concern is that can this sub work good in 0.7 cubic feet ?
I heard it before but in a bigger enclosure
http://www.focal.com/fr/expert/281-sub-p-25-db-3544052750126.html
The volume would work well, especially with the corner loading you will get.
Big thanks Xtrem, i'll try to meet the guy and buy the sub and the amp.....after it will be time for the fiberglass enclosure ;-))
ok, since Fridays night i'm now the happy owner of second hand Focal P25DB sub , a JL audio XD 300.1 amp, and a crappy generic sub enclosure
XtremR i just send you a PM with my info
3
Wanted to post an option for those who are wanting a vehicle specific subwoofer enclosure for the 2013-14 Chevy Cruze. 256 Motoring is the manufacturer of the Chameleon Enclosure line of vehicle specific subwoofer enclosures located in Huntsville, AL. The Cruze enclosure comes finished in factory match carpet, loaded or unloaded, and come painted to match your factory paint code as an option. There's a few PROMO Codes floating around for this model but the Promo Code "CRUZE2013" (without the quotes) is for $250.00 off of the regular retail price of $499.99 when buying online.
Direct Information: Chameleon Enclosures.
Car subwoofer Vehicle audio Loudspeaker Subwoofer Audio equipment
Footwear Bicycle part
Would this sub be a good fit for one of these boxes?
Dayton Audio TIT280C-4 10" Titanic Mk III Subwoofer 4 Ohm | 295-414
No. The Dayton HO 10" would be though.
Sent from mobile.
What would you recommend for a set-up considering I know nothing about this. I listen to mostly rap and electronic (bass heavy) and would prefer a system that takes minimal space and still has the power I'm looking for. Which sub/amp set up and which box of yours would you recommend? I'm really considering purchasing from you. Also can you ship one with a sub and amp already set up? Sorry for all the newbie questions but I really know nothing so I need you help to inform me. Thanks get back to me ASAP! :)
Hey X, what holds the enclosure in place when it's tucked in the corner like that?
I'd be interested in a carpeted one somewhere down the line. Need to work on performance stuff first.
Sent from my Note 3
if you get a sub that would make up good with the sub box specs it would sound much better
Sent from my Note 3
You can put a screw through the floor of the box or just use some Velcro
Yep.
Would an Alpine type R 10' be good for this?
Yes, that would work well.
21 - 40 of 54 Posts
