Let me start off saying this I do not see this car as a performance car, but the inner child in me wants to hear moar turbo noise...
So I have been playing around to find out what will and will not work. first unusual thing I noticed about the intake ducting on this car is that GM did not put any "silencers" on it. They usually put them all over on NA cars, they are large unsightly and make things to quiet.
With out any silencers in place I had to dig a little deeper. I popped out the air box and noticed a pre-air-box piping to be very similar to how Subaru does theirs.Other than this one opening the air-box is completely sealed off. Air flows right from the front of the car into ducting that runs up to the air-box.
GM for once had a good idea. They placed a rubber surround on the air-box that fits into the ducting coming up from the bumper. So I just slipped that rubber gasket off. Removing this piece allowed for the inlet to grab more air than just the volume of the tubing while still being able to suck fresh air from it while at speed.
Now my inner child was also enthused to find that it did provide me with "more turbo noise" lol. But it was still rather quiet. So I set off to find an aftermarket airfilter that is known to be a bit more open. Enter K&N, As I posted in my "K&N" thread they were all but useless. I did order one, but it did not fit quite right, so I only had it in place for short time but WOW, it really changed the sound of things. Much much more turbo noise, and a slight improvement in the butt dyno area.
After I get my hands on the right sized filter I will be doing some testing on stock filter vs K&N so It can be determined if they are a total waste of money on these cars, like they are finding on other newer GM's.
Simply loosen the clamp @ the air box and disconnect the MAF sensor and lift the box right out, it has two rubber stoppers holding it in place one in the front and one in the rear, just lift slowly on the rubber part and it will pop out. flip the box over and you will see the "condom" sitting there, lift th one side and it will slide right off. reinstall the air-box and profit.
so in short, if you want more intake or "turbo" noise, pop out your air-box. and remove the rubber "condom" on the bottom of the box.
