I wouldnt run it. Im not a fan of "chips" they are just computer foolers that make it think its seeing something different and make mor epower. I'd rather get efi live from Fleece performance and have them tune the car.
It appears that this is something similar to a bully dog tuner, which works well in Dodge vehicles. CHIP is the name of the company in this case, not the tuning method.I wouldnt run it. Im not a fan of "chips" they are just computer foolers that make it think its seeing something different and make mor epower. I'd rather get efi live from Fleece performance and have them tune the car.
^^ThisThat said, the website appears to be based in the UK, and out vehicles are a bit different than those. I wouldn't buy one unless it was demonstrated that it was both safe and effective on the US Cruze.
It has an option so you can select the European spec Cruze or the UK Cruze. I think I'll just drive the Cruze stock for a while and give it some time and see if anyone in the US starts by this tune.^^This
Given this is sold in the UK, it is likely meant for the European spec 2.0L diesel Cruze, which is an entirely different 2.0L engine than the U.S. spec diesel Cruze.
Bully dog tuners are not "good tuners" I have taken efi live training classes and the tunes that they use in a nut shell result in add more fuel, bump timing way up and it will create more power. but its not good power. Its someky, the engine doesnt run as smooth and the longevity is affected. CHIPS in general which is what that is and the name of the fools what the computer says. it takes certain values and lowers or raise them to make the computer supply more fuel or raise timing for example. Efi live tunes you can smooth out the fuel maps and make them run way smoother and get rid of ridges in the tunes so the power doesnt plateau or drop off. Efi live cannot be beat in tuning. Also tunes can be customized for each individual vehicle and youre driving habits. bully dog or other tuners whuich just plug in are a mass produced product that works for everyone so they cant accomodate a different trubo or air intake or injectors.It appears that this is something similar to a bully dog tuner, which works well in Dodge vehicles. CHIP is the name of the company in this case, not the tuning method.
Both my former TDI's were chipped, and it's a world of difference. It was astonishing how much better they were, and if you can keep your foot off the fun pedal, the economy's about the same.I really can't see the point of tuning the diesel as a road car? It would be cheaper to buy an older car with a big engine and tune that and get some real performance.
Type: | six speed front wheel drive, electonically controlled automatic tansmission with torque converter clutch |
Maximum engine torque: | 400 Nm (295 ft-lbs) |
Gear ratios: | MDK |
First: | 4.148 |
Second: | 2.370 |
Third: | 1.556 |
Fourth: | 1.555 |
Fifth: | 0.859 |
Sixth: | 0.686 |
Reverse: | 3.394 |
F/D: | 3.200 |
Ratio spread | 6,05:1 |
Maximum shift speed: | 7000 rpm |
Min input speed: | 650 rpm |
Shifting mechanism: | Integrated position sensor with TCM |
Shifting positions: | P,R,N,D (by cable) & Tiptronic (by CAN) |
Case material: | Die cast aluminum |
Center distance: | 197 mm |
Overall length: | 358 mm |
Shift pattern: | Pulse width modulated solenoid control |
Shift quality: | Variable bleed solenoid |
Torque converter clutch: | Pulse width modulated solenoid control |
Available control features: | Eco Mode Manual Mode (Tiptronic) Up Hill Control Down Hill Control Shift by Temperature Brake Assist Neutral Control Tip Auto Down Tip Auto Up Improved Downshift Protection Highest Gear in Limp Home |
EOBD II, OBD | OBDII |
Converter size: | D241 Large |
k-Factor: | 207K |
Torque ratio: | 2.24 |
Fluid type | AW-1 (low friction), lifetime fill |
Transmission weight (dry): | 85,7 kg |
Fluid capacity | 6,96 kg (incl. cooler) |
Pressure taps available: | Access to all clutches & brakes possible |
Assmbly site: | Anjo City, Japan |
Applications: | Chevrolet Cruze |
AWTF-80 SC - Wikipedia, the free encyclopediaIf you're not using the factory over-boost frequently, then there is no point in power tuning - you're not even using what you got now.
Here's the transmission specs from the GM Powertrain web site:
Type:
400 Nm (295 ft-lbs)
Gear ratios:
MDK
First:
4.148
Second:
2.370
Third:
1.556
Fourth:
1.555
Fifth:
0.859
Sixth:
0.686
Reverse:
3.394
F/D:
3.200
Ratio spread
6,05:1
7000 rpm
Min input speed:
650 rpm
Shifting mechanism:
Shifting positions:
Case material:
Die cast aluminum
Center distance:
197 mm
Overall length:
358 mm
Shift pattern:
Shift quality:
Eco Mode
Up Hill Control
Down Hill Control
Brake Assist
Neutral Control
Tip Auto Down
Tip Auto Up
EOBD II, OBD
OBDII
Converter size:
D241 Large
k-Factor:
207K
Torque ratio:
2.24
Fluid type
85,7 kg
Fluid capacity
Assmbly site:
Anjo City, Japan
Applications:
Chevrolet Cruze
my feelings as well !!I can't wait, I bought mine just for commuting but would love some more grunt when I get on it.
I am fine waiting until a tested and true tune is available.
