I've seen other threads where folks have had issues with front brakes that click/grind/clank/rattle etc when braking, however my issue is the opposite.
When hitting certain bumps in the road (not small bumps nor large bumps, but medium bumps--yeah, I know, hard to explain) I hear a metallic clank in the front end, both sides. Similar sound to a loose suspension part such as the sway bar links, or strut, but this happened immediately after replacing the pads and rotors.
The clanking quits when I "ride the brake" going over said bumps but comes back when going over the same bumps without riding the brake.
I used Centric pads and rotors:
https://www.amazon.com/dp/B008CRE7VG?tag=vs-auto-convert-amazon-20
https://www.amazon.com/gp/product/B009WT9DQM/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
New pad hardware, new caliper guide pins.
I did not use lube or any type of paste on the back of the pads themselves.
I meticulously cleaned all mating surfaces and lubed the guide pins and shims.
Now, one thing I did notice......the pads have a slight slop in the caliper bridge/bracket/ whatever you want to call it....the gap is about .035" (measured easily with a feeler gauge) between the pad and shim.
Is that enough slop to cause this clanking???
If so, how do I rectify that? Another set of pads? Somehow fabricate a small shim to put in that gap? Use some adhesive on the back of the pad to make it adhere to the caliper?
It's driving me nuts.
