Climate control problems
6664 Views 1 Reply 2 Participants Last post by  Robby
Help!
Yesterday my 2011 Chevy Cruze died, took it in to get fixed which they said was the battery. I just got my car back, drives fine but the climate control dash is not lit up. I am unable to adjust the heat or air. Any suggetions? I thought they would check over any electrical problems when they were fixing it.
1 - 2 of 2 Posts
Sometimes, for no reason whatsoever, certain module controlled devices will lock up when the battery is reconnected.
I am assuming you did not jump start the car.
With this in mind, disconnect the negative cable at the battery and keep it away from the terminal for a few minutes......you are performing the automotive equivalent of a 'Reboot'..........after about five minutes, reconnect the cable and try again.
If all functions return....well, you had a module with its electrons scrambled (my term).
If the problem continues its back to the dealer for a look see.
1 - 2 of 2 Posts
