I actually found a PM that I traded with the guy, at the time. Travscruze was who it was. I wonder if anybody else has done it like this??
"I did replace the clutch myself, you do have to drop the exhaust all the way back to center of car. I did it with the engine completely still connected to its hoses but loose in the engine bay. Its very doable. Shops disconnect everything from engine and drop the cradle. I didn't want to do that. So i put a cherry picker on engine, VERY systematically laid out every part i took off with its corresponding bolts and even took notes a few times and sharpied the bolt heads with numbers and drew diagrams. That was mainly for the block to bell housing. They use about 3 different lengths of bolts, and being everything is aluminum, i didn't want anything stripped. After getting everything out of way, I used a very small rachet strap and rachet strapped the transmission to one side of compartment up on craddle and and the engine oil pan i sat on the opposite craddle ledge. Make sure to keep the cherry picker on it at all times. Then just swap stuff out. The #1 thing i can suggest, no matter how you do it, is to go to fastenal or a store like it and get at least two long bolts with the same thread as your bell to block, cut the heads off the bolt then screw them in a few threads, line up your transmission on to those bolts and slide the transmission and block together. It will keep the everything lined up and make it all super easy. Throw in a couple bolts in the bell housing, pull out your guide bolts and poof. just do everything in reverse.
it took me a day to take it out and a day to put it in, being super methodical and a wee bit anal. "
