In my conversations with Tom, I've discovered these things have to go through a ridiculous number of approvals in several departments. It's not exactly a one signature deal.Actually, 3 weeks is pretty quick. Consider that GM needs to get the information and any required parts to their dealerships before the first owner calls in for the recall. I have seen up to six months from the time the recall was announced to the time the first notices were mailed.
What parts? From what I read they're just going to drill holes in the existing plastic shield to let oil drain out from sloppy oil changes. Not even gonna bother taking mine in for this unless there's some other reason to bring it in - then I'll have it done.Actually, 3 weeks is pretty quick. Consider that GM needs to get the information and any required parts to their dealerships before the first owner calls in for the recall. I have seen up to six months from the time the recall was announced to the time the first notices were mailed.
Since I don't know exactly what the change is, I can't say if parts will be required or not. In any event GM must provide instructions to their dealerships.What parts? From what I read they're just going to drill holes in the existing plastic shield to let oil drain out from sloppy oil changes. Not even gonna bother taking mine in for this unless there's some other reason to bring it in - then I'll have it done.
According to the article on CNN,Since I don't know exactly what the change is, I can't say if parts will be required or not. In any event GM must provide instructions to their dealerships.
No new parts required, just hacking some holes in the exiting shield to let sloppy oil change residue drain out. I change my own oil so this is not an issue for me at this timeGM dealers will modify the engine shield by cutting away parts of it, creating holes that will allow fluids to drip through. The modification process that will take about 30 minutes.
It's really hard to tell from that picture exactly how much material is hacked away.View attachment 6225
^Did the modification to mine today. It's nothing but hacking away the panel section that sits directly under the oil pan, filter, more room for the drain plug, and the vent on the transmission. No holes required. GM doesn't want to risk ANY fluid left behind to ignite after the previous Cruze fires.
As for the Rear compartment recall, very few Cruzes are applied to this one I believe (compared to 420,000 for the shield that is). The brackets for the fuel tank should be spot welded, if they are MIG welded, you need to go in for repair. I don't have a picture of this one, so I can't show where.
Doesn't this leave a gaping hole to allow water/salt etc into the engine compartment to create damage?View attachment 6225
It is not my wish to argue with you.Lawyer to Physician client about terminally-ill patient: "...just wait long enough and your law suit will resolve itself..." (for those wise enough to "read-between-lines")
The stealerships didn't have ANY information or parts when we received our two Recall notices for our 2009 Pontiac Vibe; had to wait three weeks before we could even 'schedule' an appointment to have the car inspected to even determine if it was affected (it was) or not! Granted this was (a) after GM had thrown Pontiac out-the-door and (b) GM was still crawling out of bankruptcy, but remember GM boldly declared that they were honoring *all* Warranty obligations. Where did GM think they should *send* those Recall instructions & parts to with all their Pontiac stealerships "shuttered & closed"? Can you say: poor (or none?) forward thinking?
WOW, you gotta go way back to find any of them in RWD....also they have been adding more RWD platforms to the fray in recent years.
...I would've used the analogy: GM shot their Chevy and Pontiac FEET when they decided to eliminate RWD vehicles, which included the Impalas, Bonnevilles, etc.
I agree wholeheartedly about the Bonneville to G8 injustice ( who in their right mind would throw out a storied name and model for a meaningless alphanumeric misnomer? ), but then I ask, "and who signed-off on what the Pontiac division could do?" The answer ultimately is GM.It is not my wish to argue with you.
I usually agree with your words but I have to disagree with your sentence
"GM had thrown Pontiac out the door"
I am of the opinion that Pontiac cut their own throat.
Pontiac made many generations of Bonneville. Those that traded their Bonnie every two to four years all of a sudden are told "No more Bonnie's it's now a G8." I would really like to know the sales number difference between the last four years on Bonnie's and the first years of G8.
Like if Chevy all of a sudden says "No more Impala's its now a F6. A stupid move that would loose customers.
Just my opinion.
Reminds me of Ford when they changed the name of the Ford Taurus to Ford 500. Sales tanked, so they went back to calling it a Taurus.Pontiac made many generations of Bonneville. Those that traded their Bonnie every two to four years all of a sudden are told "No more Bonnie's it's now a G8." I would really like to know the sales number difference between the last four years on Bonnie's and the first years of G8.
Just my opinion.
Maybe order one up from gmpartsdirect now while they're still available, in case something happens to the one you've got.So they hack away half the panel. Great. Just what I need, half the protection missing. I was looking forward to an engine and transmission not molested by salt when it comes time to do the clutch.
If that underbody panel had any fuel economy effect, it could affect the Cruze's fuel economy for the worse. I got this car for the fuel economy, so anything that messes with it is bad in my book.
Here's a picture of the unmolested underbody panel:
