good morning all, so I imported to Nicaragua my 2011 Chevy Cruze 1.4LT. I was having issues with my coolant overheating causing consumption of Coolant. Mechanic said thermostat needed change, so I did change it. having same problem with new thermostat. Since Nicaragua is a hot weather country, mechanic decided to remove inside of thermostat so coolant would not overheat and be consumed. after 2 days of running I get the following message "AC turned off due to high engine temperature" funny thing is that there is no check engine light on, coolant level is high and car does not seem to be overheating!!! can someone help me find out what the problem is?
