With the advent of the EPA specification for OBD II, least the diagnostic connector is the same, but various manufacturers have played games with the codes. And practically all generic scanners have joined the comedy crowd.
To be at least little more specific, should specify the engine in your vehicle, don't leave it to assuming you have the 1.4 L turbo. Since this engine in the USA is only in its second year, really difficult to state if this code does relate to turbo problems. GM Tech II scanners are constantly being updated for new vehicle models.
It would also be good if you specified exactly how you received your P0299 code, was this from the DIC? Again you leave us guessing.
P0299 Code did start in around 2007 with the Cobalt turbo and was related to a damaged nipple on the waste gate valve or the rubber vacuum hose attached to it. The Cruze added an electrical solenoid valve in series with the vacuum line that has an electrical connector connected to it. That could also be the problem.
Anyone playing around down there, oil change perhaps, dropping a wrench?
This stuff changes each and every model year and is enough to drive any guy nuts. Ha, Henry Ford stuck with his crazy door buzzer ignition vibrators for 17 years because he didn't want to pay Charles Kettering royalties. But at least it was 17 years of stability until Kettering's patent ran out.
Same with RCA, took them 17 years before the RIAA approved their 45 rpm record with a big hole in the middle. But today, formats are changing every five minutes. In 1984 their was only nine basic alternator regulators that could handle 95% of the market at the time. Today, even though the function is identical, over 4,000 different models. And one wonders why the parts costs are so high.
With waste gate problems, what about driveability problems, certainly would have noticed a lack of performance, also good to post the symptoms.
