Shame you didn't search some.
Most likely primary code is the P0171.......lean condition.....generally caused by the integral pcv ,built into the cam cover, having a failed diaphram.
Often, it has been found that this failure frequently occurs when the check valve, that is part of the intake manifold, has failed.
Either or both components fall under the powertrain coverage.
In general, all the other codes are related and are a result of the P0171......till that is resolved, disregard the rest.
