1 - 4 of 4 Posts
As winter rolls in I'm starting to notice the smell of gasoline when I start my car up in the morning. I ordered a new purge valve solenoid, when that arrives I'll install it. Just curious if there's anywhere else I should be looking if that does not solve the issue.
I wouldn't be too overly concerned, unless you see noticeable leaks from fuel lines.... cars run richer in the cold especially on cold starts, it's not totally surprising that it smells different than usual.
Just never did before in the 4 years ive owned it
In that case then you're probably on the right track replacing that purge valve I know that's a piece people have had trouble with in the past. If you have no visual leaks I then I can't think of anything else you could do.
1 - 4 of 4 Posts
