I just had my the compression tested on my 2018 Cruze and was informed that the results were between 105 and 110 PSI across the board.
Needless to say, I was in disbelief, as the car had a major engine overhaul no less than 6 months ago, and so the mechanic was kind enough to come to my house and double check the results. He did this by removing one of the spark plugs, connecting a gauge, and starting the engine, which sputtered and ran terribly, but idled nonetheless, so that he could capture a max reading.
This was performed on two cylinders, that showed about 10% between them.
With that said and after reading several threads, I've been seeing numerous comments referencing specific conditions to get a proper reading. And so my question is, could the low compression be due to improper setup? or was the used method used sufficient in getting an accurate reading?
Thanks in advance for any help with this.
