1 - 8 of 8 Posts
2013 Cruze turbo 1.4 overheated due to leaky coolant outlet pipe, replaced, now car won’t turn over car has spark and gas removed spark plugs coolant in cylinders 1-4 Dried them out turned over the motor and they once again keep refilling with coolant just from attempting to crank what could it be blown head gasket blown intake gasket blown turbo forcing water into cylinder heads I’m stumped
Whatever it is. The head probably has to be removed anyways.
Could be gasket or worse case. Cracks in the head. Or other reasons you picked.
Discussion Starter #3
could changing the intake gasket solve the problem of coolant entering the cylinders, Is there any way to determine if f the turbo is the culprit to the fluid filling the cylinders
2013 Cruze LT
No, as previously stated, the head needs to be pulled. You risk doing even more damage if you don't and continue to run it.
Discussion Starter #5
Ok so just to be clear there isn’t any other way for coolant to pool in the cylinders accept through a bad head?
Well. Since your problem is cylinder specific. That leans more towards the head or gasket. Or along those lines.
If it were the turbo. You'd be all 4 cylinders. I would think anyways.
Others might chime in with other possibilities.
Not likely
Reactions: Thebigzeus
1 - 8 of 8 Posts
