Recently I was out of state and the radiator suddenly failed, very strange but i get it, the car is lowered maybe i hit something and it busted. but now after replacing the radiator it keeps leaking, at a very slow rate but overnight or even after a few hours maybe 20 to 30 drops are visible on the floor. I've been able to locate the leak to the lines that have the transmission fluid inside of the, where they go into the radiator tank itself, it leaks from that set of two nuts, I tried tightening the outer nut but it keeps leaking, I dont know if someone here has had the same problem, if so, please help!!! It's extremely annoying to be having to pop the hood every time that im going to go out to check on the coolant and think if im gonna overheat on my way.
