1 - 7 of 7 Posts
I apologize if this in the wrong section of the forums.
got a coolant leak from the big hose back to looks to small pump or something. (I know it’s not a pump).It’s plastic part, where the smaller hose from the reservoir and the larger hose form the radiator come together.
need help A) naming it. Lol. And B) it obviously needs swapping out.
Thanks. Now I’ll go
Search the forums. ;)
Thanks. Now I’ll go
sounds to me like you are describing a water outlet.
Yes sir
Found the part Locally
Got to try to swap it myself. My daughters car and she’s visiting the weekend. Headed back Monday.
Is the coolant drain down necessity? The resv is nearly empty. Obviously still a lot in the engine etc…
Yes sir
I didn’t drain mine when I did it. Just use a pan to catch as much as possible.
Can anyone help me my 2015 Cruz Ltz is saying transmission fluid hot idol engine what is that n how can I fix it
1 - 7 of 7 Posts
