Based on what I have found on here, when the engine overheats the thermostat has a failsafe and defaults to open position to prevent damage.
Is it possible to push the thermostat back to normal or must it be replaced?
Also looking at the parts diagram, there is a thermostat, gasket and thermostat housing with a plug. Can I reserve the thermostat housing?
Now this will happen again unless I address the issue of overheating. As I said I saw a leak when I overfilled the coolant tank k and hopefully it's the tank busted at the seam. I am going to overfill it again to check.
Prior to this coolant change it was not losing any coolant.
