1 - 4 of 4 Posts
Has anybody had problems with their 2011 Cruz not holding coolant in the engine? My heat stopped working and I thought it was low coolant but I refilled the coolant and my heater is blowing out cool air. Please help
Yes, I've had this issue. You have a leak somewhere. But to get your heat back immediately, you just need to bleed the cooling system. There are likely air bubbles preventing coolant from flowing to the heater core, so you have get those out. Pretty sure there are a bunch of YouTube videos on how to bleed the Cruze.
You have air into the coolant now, as rejesterd mentioned. The design is bad (I know what I'm talking about), read my post and see if you like my fix:
Hi Cruise Cruze I did your thermostat swap then bled muy cooling system and still and having this issue and getting to 230-240 when sitting still heat works good when car is revved up and temp drops down as well when I'm moving or revving the car
Sent from my SM-G960U using Tapatalk
1 - 4 of 4 Posts
