Hello,
I had a cooling water leak on my Cruze 2.0l 163cv 2013 engine rolling 120000kms before 4 months,
That leak is located on axe behind the diesel injector appears from the top as picture one showing and as picture two showing after uncover the engine (these pictures are not the pictures of my engine are just for explanation)
I used water leaking fixer product and it was plugged for around 10000km and it return leaking again by dropping
Can anyone help me on that, how i can fix it, and what are the possible causes of that?
By the way there is No smoke No high temperature No fault codes, and the engine work very good
Thank you
Thank you
