1 - 20 of 33 Posts
I am switching over to the coppers on Friday.. Reason being is I am having major blowout problems @ any gap on NGK's.. 1/2 to 3/4 throttle between 2k and 4k very violent shaking and hesitation.. It will cut out then it almost feels like being hit from behind with big surging, I am down to .025 and still feeling it, would anyone know the part number of the copper plug that I will need?? Also any possible suggestions that would help with the blowout or any ways to stop or prevent it??
NGK BKR7E is the plug most people are using with great success.
I haven't updated the threads yet, but I recently installed BKR8EIX Iridiums. I am not tuned, and the weather is cold, but so far these are the best feeling plugs yet. That's no endorsement for how they will work with added boost, though...
...any possible suggestions that would help with the blowout or any ways to stop or prevent it??
I've read that the extremely narrow tips on the Iridium plugs makes a more reliable spark... that could be marketing fluff, but might be worth a try if the BKR7E doesn't help.
Thanks for listing the Iridium part number. I've been wondering how that BKR8EIX does in comparison to the BKR7E others are using. When its time to change my plugs, I will probably be going with the BKR8EIX Iridium over the copper plugs, or the stock Iridiums.
That's what I am using and having problems with..
4 NGK BKR7E Iridiums
- barely over 20k on them
This extraordinary insight brought to you from the confines of my iPhone..
This is interesting. I"m having a very similar issue and it seems to be getting worse. Only 1K on my new ride. Gapped @ .028". Trifecta tuned.
Edit: Just ordered (4) of the BKR8EIX Iridium. I'll post back if it helps once they're installed.
WhiteAndBright said:
I am switching over to the coppers on Friday...
...anyone know the part number of the copper plug
So you're switching to coppers on Friday, but you've been using them for 20k? Confused!
He's using the stock iridiums and switching to the coppers, i believe.
the autolite copper is part number 3923 for our cruzes. Im running those on my cruze with a gap of 0.032 and im tuned. They are much smoother down low and zero spark blow out.
^ Having said that, why would one bother with the BKR7EIX? It's basically the same as the stock plug minus the precious metal pad on the ground electrode... ?
I am also running that same gap on those same plugs, also tuned.
Hmm. I was gapped @ .032 prior to tuning. Trifecta told me first thing before flashing, to gap them to .028
What about that regapping how-to thread?
Sent from my Note 3
Discussion Starter · #18 ·
The stock pkugs are iridium, if I'm not mistaken
Sent from my Note 3
Discussion Starter · #20 · (Edited)
Yes they are, but if you will note in my post I said I'm having blowout on the NGK's.. Factory are ACD's..
Post back when you swap yours out and what results you find..
1 - 20 of 33 Posts
