1 - 4 of 4 Posts
Could I use 10w30 oil when it says 5w30 oil on cap I used last year was 5w30 but wasint sinthetic could I use 10 w 30 or is this a big no no
2013 Cruze LT
Yes, but it wouldn’t be recommended, that is quite thicker. Also, you always want to use synthetic, don’t want it coking and gumming up the turbo.
I have used 10w30 full synthetic Amsoil on both gen 1 & 2 cars for 5 years with no problems. 30w is 30w. The 10w is thicker cold than 5w. Only diff. I don’t know where you’re located but in anything above 25f or so should be fine. Especially if you don’t crank it cold and immediately stomp it to the floor. But yes, no matter what you choose always use full synthetic.
1 - 4 of 4 Posts
