To my knowledge (since I haven't physically worked on a Cruze yet) there are struts in the front. Shocks, coil springs and a straight axle in the rear of a Gen 1 Cruze. Much like an HHR that I HAVE worked on. I wouldn't guess suspension since it's only happening during braking and the fact that it started after the brakes have been serviced. Maybe double check the brakes on that side one more time with the drum off. Be sure the primary(short) shoe is on the "front" side and all your hardware is exactly where it needs to be.
If you wanted to check suspension, check for play within the bushings where the axle mounts to the frame and the bushings for your shocks. If there's a sway bar, there will be bushings for that as well. That's about it for suspension though.
Good luck!
Good luck!
