Solution => Don't use questionable electric impact wrenches from Harbor & Freight ( Bolt is standard threading). Got a 800 ft-lb Husky air impact and had the pulley off in literally 2 seconds.
Still need something on re-positioning/timing the cam shafts with the crank as the old belt jumped a couple teeth (lesson to others -> Don't try and hold the cam's and use the old belt as your torque reversal to keep the engine from turning over). Looks like there is a mark on the snout of the crank for #1TDC...do the marks on the end of the camshafts align horizontally right next to each other (i.e. basically the two marks are horizontal and nearest to the centerline of the engine)?
Thanks,
Adam
