He can leave the head on thou lolYup I second the oil cooler. 8-10 year duty life on the rubber seals. Just sucks having to get new bolts, nuts and a new exhaust seal to do it.
Lol. Yeah I too thought it was the head, and just so thought since I'm in there I should do a pre emptive and change the oil cooler. Upon taking the head off I found no possible spot for anything to leak. But taking apart the old oil cooler the seals were baked to the block only imagine the internal seal.He can leave the head on thou lol
Wait, you took the head off to replace the cooler? OuchLol. Yeah I too thought it was the head, and just so thought since I'm in there I should do a pre emptive and change the oil cooler. Upon taking the head off I found no possible spot for anything to leak. But taking apart the old oil cooler the seals were baked to the block only imagine the internal seal.
yeah.... it was intimate lol. took a razor blade to remove the gasket, then a light 600grit polish to prep.Wait, you took the head off to replace the cooler? Ouch
