The brake light sensor is part of the pedal assembly. It sounds to me like this sensor has come loose and moved a little bit.
This. I haven't looked at the Cruze yet, but when I used to work at a vehicle assembly plant, the brake switch was just a push in and turn style switch assembly. Seemed very easy to come loose if knocked. If the switch is anything similar to that, this may be your problem. I'd grab a light and take a look under the dash at the brake pedal assembly and see if you can spot the problem.The brake light sensor is part of the pedal assembly. It sounds to me like this sensor has come loose and moved a little bit.
Thank you guys. I'll have a look near the brake pedal and see if I can spot anything.This. I haven't looked at the Cruze yet, but when I used to work at a vehicle assembly plant, the brake switch was just a push in and turn style switch assembly. Seemed very easy to come loose if knocked. If the switch is anything similar to that, this may be your problem. I'd grab a light and take a look under the dash at the brake pedal assembly and see if you can spot the problem.
Says it all, gummed up master cylinder or a screwed up brake booster. Assume 50K is KM. Brake fluid is hygroscopic, always had been and still is, further problems are created with ABS. Liars claim it does not interfere with normal braking, it sure in the HAIL does. Sticking valve prevents fluid from returning to the master cylinder, and the size of the Cruze ABS module can fit in my shirt pocket. Making these dang thing cheaper and cheaper.Sometimes releasing the clutch pedal makes the brake light turn off, but mostly it just remains on and I have to put my foot under the brake pedal and give it a pull (upwards) to make the brake light turn off.
Will do. The dealer gave me an RAC warranty for 3 months with the car. I've taken it to a garage and they'll let me know about the issues on Monday.Let us know what you find, please.
Sorry, it's 50k Miles not KM. I'm letting the garage diagnose it and they'll get back to me on Monday. The car is under RAC warranty. so it seems like it will be okay, but these warranty companies try to wriggle out of paying for nearly everything.Says it all, gummed up master cylinder or a screwed up brake booster. Assume 50K is KM. Brake fluid is hygroscopic, always had been and still is, further problems are created with ABS. Liars claim it does not interfere with normal braking, it sure in the HAIL does. Sticking valve prevents fluid from returning to the master cylinder, and the size of the Cruze ABS module can fit in my shirt pocket. Making these dang thing cheaper and cheaper.
Control is done by a cheapass microcontroller with code store in flashram, drives a power MOSFET transistor that can leak causing the valve to open at a very slow rate. AH's made this law, really tees me off since they don't even know their butt from a hole in the ground.
System should be flushed with new brake fluid at least every two years, don't let your AH dealership do this, will return your vehicle with a brake pedal going to the floor, AH's don't even know how to bleed brakes, speaking from experience with these AH's.
Then to make it even more miserable, need a way overprices scanner to activate the ABS pump because this POS always gets air locks.
And you wonder why we have problems. If those pads, can't return to home position, they drag and burn up your rotors or drums, but say this is not covered under warranty! One problem leads to another.
