Hi,
I am new here and new to Diesels. We had this Cruze for about a year without issue until my wife could not keep her car running Monday AM. She filled up on the way home Friday drove 20 miles home, parked the car for the weekend and found that it will start up run for a second or two and then stall over and over until she killed the battery. I pulled the battery cable for few minutes and replaced it going for a Hail Mary but no luck. My buddy put a scanner on it (showing no MIL's ) and found that the MASS air flow sensor was reading the wrong temp so I replaced it and no luck. I have no security light flashing. I disconnected the O2 sensor no change. I disconnected the Mass Air FLow no change except if I try a few times I can get it to idle but there is no response to the throttle and as soon as I hook up the Mass air flow sensor it stalls again.
One other thing I noticed. When you try the Onstar remote start you can hear the car go thru it sequences: doors lock fuel pump turns on but the starter motor does not get a signal to turn it just stops there at the fuel pump coming on and then you get a fail on the Onstar software. The scanner showed almost 3000 psi fuel pressure at the motor and 25 else where, I assume after the lift pump. Once I got the scanner to show the crankcase position sensor bad but when I cleared it the code would not come back, occasionally the dash message will tell me to raise and lower the driverside window? That's it any ideas? Sure would appreciate the help. My wife is a traveling nurse and I cannot turn this back over to her unless it's 100% reliable or she will skin me!
Dan
