Did you bring the transmission up to 185-205F when you adjusted the fluid level?
Your knowledge never ceases to amaze me.Yep. For the auto the transmission temp has to be within a certain range. Fluid expands and if you have too much fluid in there, it will cause aeration from being overfilled and cause a slew of shifting problems and failures. That's for this particular trans.
Transmission filter is not serviceable.
Just convert to celcius. Should be around 90C.would you like to explain about this digit (185-205F) for Fluid Level ?
