hi i bought a cruze of 2010 model it only have 38,000km on it.
My problem is the Dic light is not full lighting. and other problem is with my hazard switch is flashing while is off.Any help pls cause im bit confused and i really love my car?
Welcome. In what country is your Cruze located?
North American Cruzen had a Special Coverage issued for defective Negative Battery Cable. It’s for 2011-2015 models so probably not your situation.
http://www.cruzetalk.com/forum/25-g...al-coverage-14311-negative-battery-cable.html
Regardless, it might be a good idea to check Battery connections. Also check out the age/condition of your battery. The Cruze electrical system is very susceptible to small variances in voltage.
Reactions: keith39
Are all these lights on the instrument cluster with the speedometer? If so it could be a failing cluster. I've had these fail before.
