1 - 4 of 4 Posts
Hi guys,
Need some advice again please!
I had driven 300 miles yesterday when the engine started misfiring and the engine warning light came on. I pulled over shortly after and got recovery guy out. He read the codes and they said that it was misfiring on cylinder 2. He said I needed a new coil pack but only had spark plugs so changed them for me.
So, car now is not misfiring. I have driven 500 miles since but I still have an issue. Which is that acceleration can be intermittent ( only when revs are low). The engine jerks a little - but not as much as a misfire I think. No warning lights come on. Could these be down to coil pack or ht leads. I thought coil pack would fail completely not partially.
Thanks in advance for your help.
Cheers
Hello! How many miles are on the car? Has it ever had the spark plugs replaced before?
Thanks for reply, It has 45000 on clock. I think it had plugs replaced when I had full service 12 months ago. In that time I have done 8-10000 miles.
According to Google search results they can partially fail.
Have you rung a few mechanics and asked them the same set of questions? Don't tell them what you believe to be the cause of the problem - only the symptoms - and see if several professionals come to the same conclusion.
1 - 4 of 4 Posts
