Spacedout-
I think you're exactly right. The reason why the 2011-2012 Cruzes have the 525 CCA battery vs the 600+ in the 2013 all comes down to weight. Sure the larger batteries may weigh an additional 10-15 lbs, but I really don't think that weight will change fuel economy signficantly. I added a rear hitch to mine, and that's nearly 40 lbs, and didn't see a significant difference in mpg. More accurate weight can be found searching individual batterys. Sears I believe lists weights.
Yes, all the weight everywhere adds up, and must be considered. I've never read the actual amp draw of the starter when starting this vehicle, but I assume its fairly low, compared to a V8 normally asperated vehicle running dino oil.
One theory may be a larger battery gives a longer life simply due to the fact that a Cruze will probably operate longer at 50% battery capacity if the battery started out as a 700+ CCA, vs. the 550 or 600.
I'm not sure how much of a difference it makes, but traditional lead acid batteries have a Northern Design and a Southern Design based on were you live. It has to do with the Lead to Acid Ratio. CCA vs. cooling capacity (Boil Over Protection) for warmer climates.
The factory battery is a one size fits all, and unfortuantely I think even a standard off the shelf appropriate climate battery sized with the standard H5 series may be better than the factory battery.
I wouldn't doubt the factory battery was rated at 525 CCA because there was a weight spec on it.
