67,000 k on the 2012 rs 1.4t
Normal oil changes other than that good so far.
Looked around found this Coil AC Deco. BC-C1810 High performance Coil.
Arrived quickly and was not a complete Oem fit.
The inside pins have molding area which when connected to the harness will not connect and lock. I had to modify the lock tab on the Coil by cutting it back. This allows for the lock to secure and the pins connected to the harness.
Yes if you look at the old Coil you will see a few things. Blow out and a repaired boot. Yes that repaired boot has been going for over 40,000 k with a little Jb weld.
Running same ngk laser gapped at. 32 and loving the changes so far.
Very nice, what makes it "high performance? Is it different than the stock coil?
I am not 100% sure and have not put any testing equipment on the car yet. Purchased it as it was the same price so I thought what the heck lets check it out.
OK update.
JUNK 3 days in coil packed it in left my wife stranded at work. Lucky for me my brothers shop is across from my wife work he ordered a new coil and she got on the road. Returning it for refund. JUNK stay away
OK update.
Good to know. Was this off Rock Auto or locally sourced?
