Likely a bad connection on a battery cable or a battery no longer holding a charge. Since it started after you disconnected, the idea of a bad or corroded connection makes a little more sense.
Hold the push button with your foot off the brake until the dash lights up. Scroll through the menus & look at your battery voltage there with the engine off. You should be seeing at least 12.2V.
