1 - 7 of 7 Posts
...here are the transmission & axle ratios currently available for the Cruze:
M32(RPO: MZ0) 1.8L 6-speed manual (LS model)
Axle 3.944
_6th 0.744 x 3.944 = 2.934:1 in high gear
_5th 0.876
_4th 1.067
_3rd 1.475
_2nd 2.158
_1st 3.818
_Rev 3.545
M32(RPO: MF3) 1.4LT 6-speed manual (Eco model)
Axle 3.833
_6th 0.614 x 3.833 = 2.353:1 in high gear
_5th 0.744
_4th 0.959
_3rd 1.302
_2nd 2.158
_1st 3.820
_Rev 3.540
6T40(RPO: MH8) 1.4LT 6-speed automatic (LS, 1LT, 2LT, LTZ, Eco)
Axle 3.870
_6th 0.746 x 3.870 = 2.887:1 in high gear
_5th 1.000
_4th 1.440
_3rd 1.912
_2nd 2.964
_1st 4.584
_Rev 2.940
MFH(RPO: D16) 2.0LT 5-speed manual (Diesel, not in NA)
Axle 3.944
_5th 0.886 x 3.944 = 3.494:1 in high gear
_4th 1.121
_3rd 1.481
_2nd 2.158
_1st 3.818
_Rev 3.333
...if there are others, please let me know what RPO code, gearings and applications!
Hi! Nogales Mexico Folk here, I just ordered a 2013 Chevrolet Cruze, but here the only engine we have is the 1.8 L, and the only manual tranny is the 5 speed... is this 5 speed the same you are posting in the Diesel engine in the chart? i cant find the specs and gear ratios of mine. Thanks a lot!
Since this seems to be one of the top topics that comes up when a search for "Cruze gear ratios" is done, here are the 2012-2014 transmission gear/axle ratios.
Type:M32
6-speed manual (MZ0)
M32
6-speed manual (MF3)
M32
6-speed manual (MR5)
Hydra-Matic 6T40
6-speed automatic
Aisin AF40 6-speed automatic
Application:1.8L (LS)1.4L turbo - Eco1.4L turbo (LT)1.8L / 1.4L turbo2.0L turbo-diesel
Gear ratios: :)1):
First:3.824.274.274.584.15
Second:2.162.162.532.962.37
Third:1.471.301.471.911.56
Fourth1.070.961.071.441.16
Fifth:0.870.740.871.000.86
Sixth:0.740.610.740.740.69
Reverse:3.543.823.822.943.39
Final drive ratio:3.943.833.833.533.20
There are no gear ratio changes, I believe it's still the same transmission. Same large 1-2 shift gap which exasperates the grind, only now there's more power going through the transmission than before which will make heat issues more prevalent.
These are the gear ratios for the all the Cruze models with a 1.4 engine.
MR5 6-SPEED MANUAL TRANSMISSION SPECIFICATIONS for Non-ECO first gen
Transmission modelMANUAL 6-SPEED
RPO CodeMR5
GEAR RATIOS
First4.27
Second2.35
Third1.48
Fourth1.07
Fifth.88
Sixth.74
Reverse3.82
TORQUE CONVERTER
LUBRICANT CAPACITY (pints/litre)
Fluid Capacity4/1.8928
MAX GVW(lbs/kg)5027/2280.2472
MF3 6-SPEED MANUAL TRANSMISSION for the ECO first gen
Transmission modelMANUAL 6-SPEED (FWD)
RPO CodeMF3
GEAR RATIOS
First4.27
Second2.16
Third1.30
Fourth.96
Fifth.74
Sixth.61
Reverse3.82
TORQUE CONVERTER
Maximum Engine Torque (lb-ft/N-m)148/199.8
MF3 6-SPEED MANUAL TRANSMISSION for second gen
RPO CodeMF3
GEAR RATIOS
First4.27
Second2.16
Third1.30
Fourth.96
Fifth.74
Sixth.61
Reverse3.82
TORQUE CONVERTER
Axle 3.944
_5th 0.876
_4th 1.067
_3rd 1.475
_2nd 2.158
_1st 3.818
_Rev 3.545
Axle 3.833
_5th 0.744
_4th 0.959
_3rd 1.302
_2nd 2.158
_1st 3.820
_Rev 3.540
Axle 3.870
_5th 1.000
_4th 1.440
_3rd 1.912
_2nd 2.964
_1st 4.584
_Rev 2.940
Axle 3.944
_4th 1.121
_3rd 1.481
_2nd 2.158
_1st 3.818
_Rev 3.333
Wow! Thank you! Near to the forum and this is so helpful. Confirms the MF3 is the right transmission.
Anyone know what AH4 Transmission gearing is? Looks to be the 15-16 transmission.... the dealership told me there is "just one" transmission for all the cars.
The replacement sold at the dealer is $4500 and covers MF3 MR5 and AH4... when asked about the gearing they didn't know. However the "other transmission" they have is AH4 that is part # 19332701. According to a website I found before; the original transmission part number for what appears to be an ECO is 19332700.
However the aforementioned "replacement transmission" part number the dealer & GMPartsDirect sells is 19332699. This is supposed to cover "ALL" the M32 manual transmissions that go into our cars.
1 - 7 of 7 Posts
