Hi, I have a 2010 Chevrolet Cruze Manual Transmission (2.0 VCDI) the problems I have had with this car in the past have been unreal...
My problem now is that the thing won't start. Anytime I switch the ignition on all lights illuminate on the dash and then go off (except for the parking sensor light) and when I try to turn the key again to start the engine I just hear a click noise. If I simply leave the ignition on the parking sensor light stays illuminated, and then both the anti-skid and traction control lights come on also. the fuel warning light is on and the fuel gauge is at 0 but there is fuel in it! The electric window, horn, radio, sat nav, etc all work fine.
The car was left sitting for 5 days as I was away from home, but checked the battery with a multimeter reading of 12.39 volts. I have in the past 2 days eliminated all fuses in the car (tested), the starter/solenoid(tried to bump start), tried to also jump start using another car and also cleaned all wires(for corrosion) leading to/from battery and starter including the earth wire.
I also hooked it up to a battery booster pack but the reading was fine. Ive tried both keys to start it, and replaced the batteries in both keys but still nothing. When the ignitions on I can press the 'menu' on the indicator and the little LCD on the dash simply says "Unit 1 set" i.e. it gives me no error codes, simply asking me to set my region.
I have a mechanic coming out to look at it tomorrow but if anyone on here has any suggestions it would be really appreciated.
PS, I am from the UK (I don't know if that helps with anything to do with known faults etc in variant models.)
